Author Topic: zorro's WIP (some fat monsterlikething) update  (Read 6771 times)
Offline zorro
« on: May 17, 2011, 10:06:10 PM BST GMT »
Allright,there is actually a wire armature under there,made in the fashion Gael Gummon makes his (body of putty on wire->drill holes for limbs inser new wire etc...I am not certain wether that is the best method,but this is unlikley to get cast so I guesss no worries there :) )
Anyhow my first go at sculpting and if I am to finish it by the deadline,I really need the extra time,as the figure is far from finished,and well it all just looks a bit crap for now
« Last Edit: June 08, 2011, 08:33:11 PM BST GMT by zorro »
Re: zorro's WIP (some fat monsterlikething)
« Reply #1 on: May 18, 2011, 12:01:14 PM BST GMT »
You bugger! I feared you'd be good...
That construction technique should be fine for casting I would imagine, so olnd as the wire is a good distance into the body and the putty on the limbs is blended well at the joins. The worst I can imagine is the limbs coming off when the master is removed from the mould, that's pretty common anyway, probably 50% of the figures I've had cast have come apart after moulding. It doesn't matter as long as you get a good impression in the mould.
« Reply #2 on: May 18, 2011, 11:51:35 PM BST GMT »
Not too shabby.  You've been holding out. :)
One wee tip, at first glance: I think the mouth could be hollowed out a little.  Looks a bit like a bas-relief among all the more 3D features.
Offline Palocles
« Reply #4 on: May 25, 2011, 03:05:17 AM BST GMT »
I think you should try to do the sculpting so that it has every chance of being successfully cast.  That looks to be a nicely detailed, quality sculpt so far and there's always the option of offering the sculpt to a manufacturer like Impact.
« Reply #5 on: May 25, 2011, 11:56:59 AM BST GMT »
Re the mouth, you could try building the lips up a tad to give it a little more depth? For the tongue (is it is to be protuding rather than 'hanging' out) either add a 'pin' of wire (possibly with the exposed part flattened in a vice/between the flat part of a pair of pliers) to add stability or first make a 'former' (a bit if putty to act as a foundation BS would be good) a bit smaller than the finished tongue, let it cure and then sculpt on top.
I hope that made sense...  :?
Offline zorro
« Reply #6 on: May 25, 2011, 06:44:12 PM BST GMT »
Thanks for the kind words Palocles!
Andrew: could I avoid drilling and such if the tongue were to hang out on the side and not portruding,but rather sticking to the side of the mouth? Anyhow I have more time now that the deadline has been extended,so it might go either way.
Offline zorro
« Reply #7 on: May 25, 2011, 06:59:58 PM BST GMT »
http://www.coolminiornot.com/index/whatm/GW/id/251317
THis is what I had In my (see bottom pic from link above)though I would add more flesh to the tongue.
« Reply #8 on: May 27, 2011, 06:44:21 PM BST GMT »
No need to drill then, add the putty in a roughly right shape, blend in the very edges while it's fresh, leave half an hour or more then shape, another half hour later sharpen up/refine, continue until the putty's too cured to "relax" (when putty's 'memory' returns it partially back to it's original shape, worst with GS, better but not absent with BS).
Edit: remember that for doing sharp/hard edges ;)
« Last Edit: May 27, 2011, 06:48:39 PM BST GMT by Andrew May »
Offline zorro
« Reply #9 on: May 27, 2011, 09:28:52 PM BST GMT »
So that is what sculptors mean when they say tho most important thing to know is when to work the putty,never understood that,anyhow thanks for the detailed explenation I will keep it in mnd!v :)
Offline zorro
Re: zorro's WIP (some fat monsterlikething) update
« Reply #10 on: June 08, 2011, 08:47:39 PM BST GMT »
Bit of an update. I took the advice from Vermis and Andrew about the lips and the mouth, though it does not exactly reflect what I was going for, the toungue did not work out at all, and I ended up redoing the mouth a couple of times, as I do not have much spare time, I have no idea if I will be able to finih it in time :(
Offline Palocles
« Reply #11 on: June 09, 2011, 03:04:07 AM BST GMT »
Looking good.
You could give him a Mean Machine (Angel) style stump and a shoulder pad and call him done if you have to.
« Reply #12 on: June 11, 2011, 07:05:06 PM BST GMT »
You can make the time ;)
Lookin good!
Offline mondria
    • Midnight greys
« Reply #14 on: June 12, 2011, 02:54:11 PM BST GMT »
I like the way you redid the mouth looks much better now I wound ad a bigger upper lip but that is me
good luck
