Author Topic: How to polong the ultrafine mill  (Read 39 times)
Offline gjsohcat
« on: May 23, 2018, 02:11:31 AM BST GMT »
The service life of the ultrafine mill accessories ensures the output of the equipment so that it can continue to operate efficiently. The following is a brief description of what is regularly referred to as the maintenance of the ultrafine mill.
Once again, the system of the equipment is regularly maintained, because the system ensures the automation of the equipment, reducing the labor force, and maintaining it at regular intervals to ensure that the pipeline is free from leakage
One point is to carry out regular maintenance on the transmission part of the ultrafine mill to ensure that it has no abnormal ringing, and that the lubricant is sufficient and the temperature is not more than 60 degrees
The above description of the work of regular maintenance of ultrafine mill is very detailed. During the work process, these parts are regularly checked to ensure that the temperature of the parts does not exceed the temperature specified by the manufacturer, and the screws and other parts of the equipment must be fastened. These maintenance tasks can make the equipment better serve the milling production line.
