Author Topic: Reasonable flow process of sand making machine  (Read 58 times)
« on: May 10, 2018, 03:31:21 AM BST GMT »
Sand making machine is very important in the mine and other industries, but many operators do not work according to the articles of association in order to save time and material resources. So, the work of sand making machine can not be guaranteed, and even dangerous things may happen. It can be seen that the arrangement of the working procedure of the sand making machine is very important.
It is necessary to have a reasonable workflow for the sand maker to better play its role. So, for the sand making machine, what kind of workflow is reasonable? Let's take a look.
Working process arrangement of sand making machine:
First, check the whirling cavity of the sand making machine before driving to observe whether the door is tight, so as to prevent the material from rushing out of the whirling cavity observation door and causing danger.
Two, the starting sequence of sand making machine and conveying equipment is: discharge, sand making machine and feeding. Note: the crusher must start at no load and can be supplied after the crusher runs normally. The shutdown sequence is the opposite of the boot order.
Three, the feeding particles of the sand making machine should be strictly required according to the requirements, and the prohibition is greater than the specified material entering the crusher. Otherwise, it will cause the imbalance of the impeller and the excessive wear of the impeller, even cause the blockage of the impeller passageway and the central feeding tube, so that the crusher can not work normally, and the bulk material should be eliminated in time.
Four, when discharging equipment stops, it should stop feeding in time, otherwise, it will cause the impeller to be crushed and the motor will be destroyed.
In order to ensure the continuous and normal operation of the sand making machine and give full play to the production capacity of the equipment, the users of the sand making machine should pay attention to the correct operation of the sand making machine from the thought, and maintain and repair the sand making machine regularly and regularly in the actual operation.
The correct use of sand making machine is one of the important factors to ensure the continuous and normal operation of the sand making machine. Improper operation or negligence in the process of operation often cause equipment and personal accidents, so the correct operation should be carried out strictly in accordance with the regulations of the operation in order to ensure the smooth work of the sand making machine.
