Author Topic: How to Prolong the Life of Grinding Mills  (Read 51 times)
Offline kuangshanposui
« on: April 28, 2018, 04:30:40 AM BST GMT »
Grinding mills are mainly used to grind and process calcite, limestone, marble, potassium feldspar etc. First of all, during the operation of Ultrafine Mill, there should be specialized staff responsible for guarding the machines, and the operating staff must have the good technical level. Before the installation of grinding mills, it is necessary to conduct technical training for the operating staff´╝îSo that they can understand the principle performance of grinding mills and be familiar with the operation process. In order to make grinding mills work normally, Equipment Maintenance and Safe Operating System needs to be instituted to ensure the long-term safe-running of grinding mills. Moreover, it is necessary to reserve some maintenance tools and grease accessories.
Next, Ultrafine Mill should be examined and repaird after using a period, and the quick-wear parts such as grinding roll, grinding ring and scraper knife should be repaired and replaced. The bolts and nuts should be checked carefully before or after the use of grinding roll device. When replacing grinding roll after using for more than 500 hours or so, it is necessary to clean various rolling bearings and replace quick-wear parts. As to the fueling tool, manual refueling or grease gun is a good choice.
Finally, grinding mills should be operated in strict accordance with the instructions. If the equipment breaks down halfway, it can't be modified at random but should be maintained by professionals and technicians. This material is a common processing material. The fluorite powders that are processed by the fluorite ball mill can be widely applied in such industries as chemical industry, rubber, ceramic, construction, building materials. The super fine powders have even wider application and have been widely used in high-tech industry such as military project and electric cable, fibre transmission and high-precision metallurgy industry. Our company has been adhering to the concept of 'people-oriented, customer supremacy, development and innovation'. We are able to provide our customers not only the highest quality products at the most favorable price, but also the most reasonable suggestion of equipment, optimum process configuration, and a full range of technical support.
