Author Topic: Features of Disk Granulator in Compound Fertilizer Production Line  (Read 89 times)
« on: March 14, 2018, 08:47:47 AM GMT GMT »
Ore milling equipment is the compound fertilizer granulating machine that we usually refer to and it is mainly composed of big disk, big gear wheel, transmission part, machine frame, pedestal, doctor holder, unpowered scraper. ore milling equipment from Shanghai SBM Mining Machinery Co., Ltd. has three discharging mouths, which is suitable for intermittent production, thus effectively improving working efficiency and reducing labor intensity. This disk adopts arc structure with a certain inclination, so that the materials will form a clear level difference, which is conducive to the collision and friction of particles with different sizes and makes the pelletizing efficiency as high as over 93%.
Features of Disk Granulator in Compound Fertilizer Production Line:
1. The pelleting disk of ore milling equipment adopts integrated arc structure which makes sure the pelletizing ratio reaches as high as 93%.
2. The adaptability of raw materials is very wide. The ore milling equipment produced by Shanghai SBM Mining Machinery Co., Ltd. can be used for pelletizing with various raw materials in many industries such as compound fertilizer, pharmacy, chemical fodder, coal and metallurgy and it can be used for producing compound fertilizers with different density and types.
3. SBM ore milling equipment has three discharging mouths, which is suitable for intermittent production, thus effectively improving working efficiency and reducing labor intensity. In addition, the reducer and electromotor adopt flexible belt transmission with stable start, thus slowing down the impact and extending the service life of the disk granulator.
4. This equipment has simple structure, convenient adjustment and excellent performance.
5. SBM disk granulator can be widely used in gold dressing plant, coal plant and chemistry, infrastructure construction and mechanical foundry for continuously, evenly and quantitatively feeding and dozing.
6. The lining of the disk is made of high-strength glass fiber reinforced plastics which is antiseptic and durable. The heavy, thick and solid pedestal design does not need foundation bolt for fixation and the operation of this machine is stable.
