Author Topic: Laminate flooring  (Read 19 times)
Offline qizhen0809
Laminate flooring
« on: March 13, 2018, 01:27:46 AM GMT GMT »
Laminate flooring
The high-density substrate board is the third layer, which is the most important and is the key to measuring the quality of a laminate floor. The price is higher than other boards.pvc fence price calculator However, ordinary particle board composite flooring is relatively cheap, so this is a more important factor in the price of laminate flooring. Substrates made with good substrates are dozens more expensive than wood chips.
Surface wear resistance
One of the most important features of laminate flooring is that it is more wear-resistant. According to national standards, laminate flooring is divided into primary and secondary grades. The family uses one grade,outdoor wood plastic composite handrail wpc fence the wear-resistant rotation number is greater than or equal to six thousand revolutions, and the secondary laminate flooring is wear-resistant. The number is greater than or equal to four thousand revolutions. The number of wear-resistant rotations depends mainly on the content of aluminum oxide in the floor. Therefore, the higher the number of floors, the higher the price of laminate flooring.
Floor brand after-sales service
The flooring industry is still very hot now. There are many brands and it is important to choose the right brand. Everyone should look at the quality when buying laminate flooring, then look at the price, and finally look at the material for patio floor Because a brand wants to have a foothold in the market, it will pay a lot of hard work, the higher the brand awareness, the better the reputation, the production of the craft materials will generally be better than other ordinary brands, of course, the corresponding price Will be higher. Many consumers now only pay attention to purchases and do not pay attention to after-sales services. A good brand of flooring companies will provide one-stop service, from production to after-sales service are all thoughtful,how to make a bench seat with backrest so that consumers worry and effort. In this case, after-sales service is good, and the price of laminate flooring will also increase.
