Author Topic: The high crushing ability of stone crusher equipment  (Read 49 times)
« on: March 08, 2018, 03:12:44 AM GMT GMT »
As is known to all, stone crusher equipment is professional ore crushing equipment, in the iron ore crushing production, stone crushing equipment can meet the production demand, in general, jaw crusher and cone crusher can be used as the production of two broken phase, jaw crusher is a common primary crushing equipment, cone crusher can be used as a medium and fine crushing plant. In addition, in order to be able to more fully use the stone crusher equipment, we can also choose to auxiliary equipment vibrating feeder, vibrating screen, cone crusher, jaw crusher in the complete iron ore crushing process equipment performance is good, the cone crusher, with its excellent performance and high crushing capacity to get customers.
Stone crusher is the medium and finely crushing plant in crushing equipment, in general, after the installation of jaw crusher, stone crusher according to customer needs, we also can install impact crusher, cobble system sand machine equipment. According to the hardness of the rock, the granularity of feeding, the range of output granularity and the crushing ability, select the appropriate rock crusher, so how do we start the preparation of the rock crusher in the crushing plant?
First, before starting the stone crusher, we should check the stone crusher wearing parts, such as stone crusher concave bowl and plate, stone crusher operators need to check whether the parts is installed correctly or loosen. It determines the life of the stone crusher. Secondly, we must check the lubricating system of the rock crusher, fill it with suitable grease, and clean it every three months. Attaches great importance to the oil temperature rise, control the range of 55 ° C, to ensure the smooth running of stone crusher in the crushing equipment.
Again, stone crusher operators must regularly check and ensure that stone crusher working conditions, the best is equipped with magnetic separator, it can protect the stone crusher in the crushing cavity damage of the metal.
