Author Topic: Now that you have all these great new moves  (Read 56 times)
Offline nbammoak
« on: February 28, 2018, 07:52:07 AM GMT GMT »
Beat The Shot Clock By Trying These NBA 2k18 Tips!
NBA 2k18 begins as a new adventure for most. You learned the basics: dribbling, passing and shooting. Today, you are probably a lot more confident. The following article will show you that you still have much to learn.
Learn proper dribbling.  NBA 2K18 MT Coins  Use the fingertips, not the palm, for the best dribbling. You retain much more ball control this way. You should be dribbling the ball at your side instead of in front of your body. The ball should always be dribbled at waist level. Always look up and never look down at the ground.
When you are practicing your shooting, take the practice shots you would attempt during the game. You are rarely going to be open for long enough to get your feet planted and line up the shot, so shoot on the move. Practice off dribble and shooting while moving for better results at game time.
To become a better dribbler in basketball, practice with your eyes closed. This will help you to be able to dribble while keeping a close watch on the action of the game. Be sure to practice while you're moving too, so that you can dribble and maneuver around the court without ever having to look down at the ball.
Practice catching the basketball while you are moving and stopping cold for a shot. NBA 2k18 is a fast paced game, and the constant movement can throw your shot off during game time. This is especially true if you've practiced your shooting standing still. That is not as common in a game experience. Get the feel for moving, stopping, and shooting.
When rebounding, start moving as soon as the shooter uncoils. When you react and move quicker, you better anticipate their moves and get more rebounds. When they start to uncoil, start contact by blocking them out. Make sure to do the same thing on offense since the shooter will most likely try to uncoil after the rebound. This can boost your number of rebounds.
Always remember that to be a great basketball player, you've got to be a great athlete first. Put as much time into conditioning your body and increasing your endurance as you do shooting and passing. This will improve your play under even the most excruciating circumstances, making you an invaluable team member.
If your son or daughter wants to play high school basketball, they need to work on core muscle training. Core muscles are comprised of the hips, lower back, and abdominal muscles. The core is the muscle group that links the arms and legs together. If their core strength is poor, then so will their athletic performance be. A strong core provides a center of force that can be tapped through the legs while running and jumping during games.
Try yoga to improve Cheap NBA 2K18 MT Coins your basketball game. You might not want to tell your teammates about it, since some of them are going to likely laugh. However, the increased flexibility and agility you get helps prevent injuries or at least leaves able to get back up quicker when you get knocked down. Don't laugh; Kareem Abdul-Jabaar used it to extend his NBA career.
Now that you have all these great new moves, you can improve your game dramatically. Set and follow through on goals to become more skilled. Using these tips, you will see you game skills improve with each game.
