Author Topic: The key to increase the output of the whole sand production  (Read 121 times)
« on: February 28, 2018, 07:25:59 AM GMT GMT »
Sand production line is the main source of construction materials, sand production line is composed of a lot of machines and equipment, sand making machine which is a very important equipment, has a very large impact on the production of sand production line, sand production line is influenced by a variety of reasons in use. In the process of its operation efficiency, internal and external are, if not timely solve it will directly affect the production efficiency of sand making machine.
First of all, we need to find out the reasons that affect the efficiency of the sand making machine, then analyze and sum up experience in the analysis, then summarize our own way. We first need to find out the reasons from the sand making machine itself, and see if its design is reasonable, and whether the adjustment of feed and discharge port is within the specified parameters. After checking these, don't forget to check the parts of the sand making machine, because the damaged parts will also cause the low efficiency of the sand making machine in the work process.
When choosing the replacement parts, choose some good wear-resistant accessories, so that the production efficiency can be improved, and the use time of the parts can be increased. The quality of the fittings directly determines the overall performance of the sand making equipment. The improvement of the quality of the sand making machine is an important point to improve the production of the equipment of the sand making machine.
