Author Topic: Sand making machine is the key equipment in sand plant  (Read 127 times)
« on: February 22, 2018, 03:50:38 AM GMT GMT »
Sand making machine is the key equipment of sand production line plays a central role, so sand maker machine can be normal and efficient operation to a certain extent on the sand production process has a great influence on sand production in the process of operators also need to pay attention to some operational matters, to to ensure the efficient operation of equipment:
1. we must ensure that materials such as broken iron and broken steel can not be mixed into the material of sand making machine. In order to ensure the safety of personnel, people who have nothing to do with production should be far away from the equipment.
2. the turning direction of the impeller of the sand making machine can not be turned back, and it is found that the reversing may be the failure of the equipment.
3. the sand machine equipment in operation should not have abnormal vibration or noise, otherwise the machine should stop checking.
4. periodically check the tightness of each connecting bolt to avoid the equipment damage caused by the loosening or falling off of the bolt.
5. lubrication and equipment in each class are required to add new oil, lubricating oil is special super 3# grease bearing parts, ensure clean and good lubrication.
6. the transmission belt should have a proper tension. When the double belt is driven, the current difference between the two motor can not be greater than 15A.
