Author Topic: the importance of ultrafine mill in the cement plant  (Read 53 times)
« on: February 21, 2018, 03:19:38 AM GMT GMT »
In the series of pulverizer products developed by the company, there is a series of common series, that is ultrafine mill. This Ultrafine Mill has an important role in the production of cement. With the rapid development of the domestic real estate, real estate and related downstream industries have been developing very fast, the industry, ore processing in cement production machinery manufacturing industry have made great development, and the development process in cement production industry, cannot do without the help of ultrafine mill.
Cement is necessary for building construction products, and is mainly sand, water mixing into concrete, cement in concrete production plays the main role is the binder, and the steel and concrete production is the main material for building construction, from this point we can see that an important role in the construction of cement built in.
Cement is a widely used product. In order to meet the demand for cement in the market, many customers are engaged in cement processing and production, so how is cement produced? Generally speaking, cement is the process of processing ore powder after firing. Mineral powder is an important material for cement production, so to produce cement, we first need to produce mineral powder.
There are many kinds of different kinds of ore powder, because it was obtained after grinding, ore is different, and in the production of cement powder needed is mostly obtained by limestone after grinding, grinding into powder or limestone, is a raw material for cement production.
Because in the cement production of limestone powder fineness requirements are not very high, so we used to ultrafine mill powder grinding is different from other milling equipment, we usually use ultrafine mill to grind limestone in cement production, because the vertical milling machine company development and production to grind limestone, limestone and the ground below 650 mesh the fineness, and customers through the finished material fineness regulation can accurately adjust the fineness of slag, limestone for specific processing, so as to meet the requirements of cement production, in order to serve the construction industry, so as to bring economic benefits to customers.
Ultrafine mill is the most commonly used equipment in cement production. It can not only be used as grinding material for limestone and other raw materials, but also can be used for the production of desulfurizer, so as to help the flue gas desulfurization of cement plant after burning, so as to achieve environmental protection production.
