Author Topic: How Not to Miss the Deadline  (Read 157 times)
Offline Piper14
« on: February 06, 2018, 01:47:43 PM GMT GMT »
There will always be times when you’re required to write an essay uncomfortably quickly, whether because of a tight deadline imposed by a teacher, or because you’ve been so busy that the essay has ended up being put off until the last minute. However, it is possible to produce a good piece of work even when very pushed for time, and in this article, and I have found much interesting about this topic at prime essays.
*Write your notes directly into the document
* Switch off your phone and social networks
* Reference as you write
* Read the question carefully
* Don't overreach yourself
Spending time on an essay, and doing it in advance, will always provide the best results (and put you in the lecturer's good books.) But we all stray sometimes, so try not to rush through your work and stay calm. One advantage of starting late is that the whole horrible ordeal will soon be over. What are your tips? Feel free to share it.
