Author Topic: Crushers are the Energy Efficient Equipment  (Read 127 times)
« on: January 12, 2018, 04:00:31 AM GMT GMT »
<p>During the project construction process, we have different particles demands on the gravel material according to its different functions. According to the particle size, the crushing production line should equip with homologous crushing equipment. Currently, there are many industries need the small sized materials. The small sized material needs the good crushing equipment. The Ultrafine Mill  that produced by Henan have the advantages of reasonable structure, good materials, stable operation; they are the commonly used equipment in the fine stone production line. The crushers are commonly used for crushing the limestone materials, sandstone, quartz and the phosphorous ore.</p>
<p>Compare with other equipment, the crushers have the following advantages:</p>
<p>1. The maximum feeding size of the material can reach 1800mm and the discharging size can below 5mm.</p>
<p>2. The gross investment of these crushers can save about 35%- 50% of the whole investment.</p>
<p>3. These crushers can save the operation costs about 30%-40% when compare with other crushers.</p>
<p>4. The floor space of this equipment can save about 40%-60%.</p>
<p>5. The long services life of the wearing parts can reduce the maintenance times and costs.</p>
<p> crushers are designed with reasonable structure and strong function. They are mainly used in cement, metallurgy, construction, building materials, and power plant desulfurization industry. This machine has the advantages of high efficiency and low consumption, which can bring huge profits to the customers. In the crushing industry, thinks that the exploitation of the crushing machine is a long terms of work and it should connect with the market demand. try their best to improve the added value of the machine and set a famous company brand to be a good example of this industry.</p>
