Author Topic: the structure of the limestone ultrafine grinding mill  (Read 75 times)
« on: January 05, 2018, 02:23:25 AM GMT GMT »
Because the ultrafine grinder equipment is designed on the basis of general milling equipment, so it gives enough advantages in the production area, so that its production can maintain stable and high yield. The ultrafine mill is the equipment which is crushed again after the raw material is broken. It is widely used in the industry of mineral processing, building materials and chemical industry. The pulverizing equipment is more precise than the general grinding equipment when it is manufactured, so its performance is also guaranteed. In the production process, it can provide stable production for users and achieve a good harvest of users.
In design, it has a lot of advantages, which is one of the reasons why he can stabilize production and have good performance, and is one of the most important reasons. When it is produced, it has strong adaptability to material and large production capacity. It is easy to adjust product granularity and grinding ratio. It can perform dry or wet operation, and also can combine drying with grinding. At the same time, it has simple structure, reliable operation, strong durability, convenient maintenance and management, and can run continuously for a long time. Not only that, its airtight property is good, it prevents the bad production phenomena such as dust and so on, which brings great convenience to users' use, accords with the requirements of the environmental protection department, and avoids the delay in production process and affects the benefit because of the need to suspend business.
In general, the milling equipment to give users a good experience, it is also one of the reasons it can be sold. So, in production, its good performance gives it a stable production state. What is the cause of this? It looks at his structure.
Because the main bearing of the limestone ultrafine mill adopts large diameter double row aligning rod bearing instead of the original sliding bearing, which reduces friction, reduces energy consumption, makes the mill easy to start, and reduces some malfunctions during start-up. The mill preserves the end cover structure of the ordinary mill, the large diameter inlet and outlet and the large amount of treatment. In production, there is no inertia impact, the equipment runs smoothly, and the time of shutdown and maintenance of the ultrafine mill is reduced, and the efficiency is improved. The feeder of the pulverizing equipment is divided into two parts: a combined feeder and a drum feeder. The structure is simple and the body is installed, so that it can achieve high efficiency in installation.
