Author Topic: ultrafine mill accessories can improve grinding efficiency  (Read 27 times)
« on: January 03, 2018, 10:53:05 AM GMT GMT »
As a ultrafine mill with high single operating ability in the grinding powder, it has a strong competitive advantage in the grinding process of metal ore and non-metallic ore. Ultrafine mill can achieve multiple functions of crushing, grinding and grading, benefiting from the high performance of its accessories. Below we classify the ultrafine mill parts according to the structural features.
The transmission components of ultrafine grinder include reducer, elastic coupling, overrunning clutch, torque limiter, tensioning sleeve, locking disc, pneumatic motor, drive belt, transmission chain and so on. The driving part is the source of its crushing power, and the material is grinding on the grinding disc by grinding roller to realize the standard granularity grinding. The energy consumption can be reduced by 30% to 40%.
Hydraulic lubricating component of ultrafine mill.
The hydraulic and lubrication components of ultrafine grinder are made up of oil pumps, hydraulic components, hydraulic motors, filters, high-pressure oil pipes, heat exchangers, thermometers and pressure gauges. Hydraulic devices are of great importance for their automatic production level. The size of the material can be adjusted, and the hydraulic device can discharge the material from the grinding chamber to avoid the wear and tear of the equipment when the material is not broken.
Ultrafine mill grinding system components is the main structure of non metallic minerals and stone grinding part, has an important influence on ultrafine mill assembly, ultrafine mill and ultrafine mill core, torsion bar, ultrafine mill grinding roller seal, superfine grinding rod, ultrafine mill hydraulic cylinder, ultrafine mill vibration tester, hydraulic cylinder seal, grinding lock air valve with these parameters on the product yield and the fineness of the material.
