Author Topic: Playing with a Laser Cutter  (Read 8310 times)
ironmammoth
  • Guest
« on: November 12, 2010, 01:19:38 PM GMT GMT »
I have just got a laser cutter for my workshop at work, so as part of my familiarizing and learning to use it I knocked out this model this week.
The doorway is approximately 40mm high.
Offline captainspud
    • CaptainSpud.com
Re: Playing with a Laser Cutter
« Reply #1 on: November 12, 2010, 02:58:26 PM GMT GMT »
Materials, time to plan, time to "print", amount of post-cutting assembly, rough cost, etc?
<-- still jealous
"How did you know you weren't really going crazy?"
"The voices in my head kept calling me Bruce."
"Yeah, and?"
"In my head, that's not what I call myself."
ironmammoth
  • Guest
« Reply #2 on: November 12, 2010, 03:16:47 PM GMT GMT »
Materials =
300mmx300mm sheet of 6mm MDF = pennies
200mm x 200mm sheet of 2mm MDF = even less
Time about 4 hours, but this was mainly learning to use Corel Draw and the laser cutters "print driver".
Also I now have the stone wall pattern (about 1 hour to make) available for other projects and also the roof tile pattern (which I probably wont use again as it is pretty much a cartoon roof).
Actual cutting time on the machine was around an hour (engraving all those stone walls was pretty slow). If I had just done plain walls the thing would have taken about 10 minutes or less to cut). But f course I can be doing something else while the machine is running through the cutting...
Offline captainspud
    • CaptainSpud.com
« Reply #3 on: November 12, 2010, 06:27:45 PM GMT GMT »
I'm having delicious visions of mass-producing wargame terrain for my store (currently I have to manually build 8+ copies of everything I make to accommodate multiple tables at tournaments).
Darn you and your awesome toys...
"Yeah, and?"
ironmammoth
  • Guest
« Reply #4 on: December 10, 2010, 11:12:02 PM GMT GMT »
« Reply #5 on: December 15, 2010, 12:28:09 AM GMT GMT »
Shoot, I knew there was something else I forgot to comment on...
Link's a bit funny.  This 'un works.
http://pulp-zen.blogspot.com/2010/12/laser-cut-wargames-scenery.html
Thanks for the heads-up.  Impressive blog post, let alone impressive laser cutter. :D  Brilliant results too - the paintstation especially.
In the video, what exactly is making all the background noise?
ironmammoth
  • Guest
« Reply #6 on: December 15, 2010, 04:33:45 PM GMT GMT »
The noise is a combination of the extractor unit (sits next to the laser cutter itself) and the cooling fans that stop the laser cartridge overheating.
It is not excessively loud, but I wouldn't want it actually in my office.
Thanks for fixing the link btw!
Offline dracon magis
    • one off minis
« Reply #7 on: December 15, 2010, 04:37:06 PM GMT GMT »
can the paint station ship to the US without too much postage?
ironmammoth
  • Guest
« Reply #8 on: December 15, 2010, 04:50:24 PM GMT GMT »
To be honest, the paint station was a personal project, and I hadn't thought about selling it (seriously anyway).
I can weigh it and let you know what the shipping cost would be. I will also have to work out a price for it...
Not to mention draw up an instruction sheet for it!
Offline joseanes
« Reply #9 on: February 22, 2013, 09:36:44 PM GMT GMT »
I have also been trying to do some laser cut wargame terrain.  The designs are freely available.  If you improve on them, please let me know what you come up with - I may be happy to cut a copy and play with it as well.
Fun Elements Website - Wargame Terrain
ironmammoth
  • Guest
« Reply #10 on: March 01, 2013, 03:32:22 PM GMT GMT »
Nice work.
I have taken it quite a bit further now.
« Reply #11 on: March 06, 2013, 08:03:05 PM GMT GMT »
Looking good. :)
Something that just occured to me: how are the laser-cut textures for painting?
« Reply #12 on: March 06, 2013, 08:29:55 PM GMT GMT »
I've only painted over a couple of the Sarissa stuff and a few Fenris bits and just used paint testers (for wall paints) and a mixture of Vallejo & really old Citadel/ GW paints, no primer.  Works ok, with lighter colours you'll need a couple more coats over the 'burned' parts.
Texture still shows thru unless you slap on the paint very thick- so it's not that easy to accidentally cover up the e.g. stone texture on buildings.
