Author Topic: ultrafine mill won the customer's favorite by its unique advantages  (Read 32 times)
« on: December 28, 2017, 10:31:09 AM GMT GMT »
The production of the ultrafine mill is that the users of the market have new requirements for the grain size of the mill, so it is the symbol of the strength. Here, the Ultrafine Mill is a typical example of the whole industry. We uphold the principle of "service first" and provide users with a batch of excellent products, which makes users in the process of using no worries.
The new ultrafine mill has a competitive advantage in performance. It has been improved on the basis of the general mill, making it more durable than other mills, and more consistent with the production requirements.
First, it is efficient and energy saving. When the fineness of the finished product and the motor power are the same, it will produce more than twice the output of the airflow mill, the stirring mill and the ball mill.
Second, its safety and reliability are high: because there is no rolling bearing and no screws in the grinding chamber, so there is no problem of the bearing and its seals being damaged. There is no problem that the screws are easy to loose and destroy the machine, which is guaranteed in the safety production.
Third, its vulnerable parts have long service life: the grinding roller and grinding ring of the ultrafine grinding are made of special materials, so that the use of the ultrafine mill is greatly improved. Under the same material and finished product fineness, the service life of the worn parts is 2-5 times longer than that of the general mill, usually up to more than one year. When processing calcium carbonate and calcite, the service life can be up to 2-5 years.
Fourth, the product fineness high: the ultra-fine grinding fineness can reach D97 time less than or equal to 5 mu m.
Fifth, environmental protection and cleanliness: ultrafine grinding uses impulse dust catcher to capture dust and noise reduction by muffler. It has the characteristics of environmental protection and cleanliness, and is completely in line with the environmental standard of the home, and it can be used safely.
Ultra Fine Mill: http://www.ohiointernationalfund.com/products/grinding/xzm-ultrafine-mill.html
Ultrafine Mill: http://www.hotverticalmill.com/ultrafine-mill.html
