Author Topic: Don't allow your feet to cross and it will be hard to get around you.  (Read 86 times)
Offline mmotanknba
« on: December 13, 2017, 06:25:35 AM GMT GMT »
The key for controlling the ball control is to spread your fingers. This will keep the ball from getting away while you to be sure that it won't escape your grasp when trying to hold it. Your palm should not be touching the ball as little as possible.
Pay close attention closely to the shoulders if you're starting to slump when you shoot.If your shoulders aren't properly positioned, you may not be able to make the shots. Be sure shoulders always remain squared up to the hoop. You want your dominant shoulder in perfect alignment with the rim.
To become a reliable free throw shooter, practice and develop a routine you will use during each shot. This might mean that you dribble the ball twice, touch your forehead, touch your forehead, or do anything else. As long as it's quick, it becomes easier for your mind and body to prepare for the shot.
You need to constantly disrupt your opponent if you want to be successful as a defensive NBA Live player. Don't let your opponent get comfortable. Be aggressive as you execute.Do not allow them to choose the shots.
Good footwork can really help you to get rebounds off your teammates' foul shots. The defender may be coming toward you, so find a way to slip around him and get to the ball. This allows you to score a rebound without finding yourself penalized.
Don't allow your feet to cross and it will be NBA Live Mobile hard to get around you.
Strength and flexibility training can improve your skills in basketball. Stamina and physical strength are two things you need to do well in this sport. Even young children can benefit from the game. As they grow a bit older, weight-lifting can be beneficial.
Always stay low when you are playing defensively. This will help you to jump or react quicker. Remain in a good defensive pose always. If you need to block the opposing team's shot, quickly get back into that good defensive position.
