Author Topic: construction waste crusher is the ideal processing equipment  (Read 104 times)
« on: November 02, 2017, 06:41:12 AM GMT GMT »
Construction waste crusher is our company years to carefully build the construction of garbage broken products, broken crushing effect is good, excellent equipment performance, access to domestic and foreign customers unanimously approved. Construction waste crusher with a selective crushing effect, and broken product size is more uniform, the shape of the majority of cubic stone. For the construction of bridges, high-speed road construction, terminals, airport construction has a wide range of applications.
The construction waste crusher is suitable for all kinds of coarse, medium and fine materials (granite, limestone, concrete, etc.) with a side length of not more than 500mm and a compressive strength of not more than 350 MPa. It is widely used in hydropower, expressway, artificial gravel And gravel, stone production, broken and other industries.
The construction waste crusher is the ideal processing equipment for high-grade road surface and hydropower construction aggregate. It is widely used in the fields of expressway construction, water conservancy engineering and building crushed stone processing with its excellent performance and good performance.
The construction waste crusher is a kind of new and efficient gravel equipment, which is characterized by small size, simple structure, large crushing ratio, low energy consumption, large production capacity, uniform particle size and selective shredding effect.
construction waste crusher: http://www.hotquarrycrusher.com/products/crushing/construction-waste-crusher.html
