Author Topic: Ultrafine Mill Structure And Working Principle  (Read 239 times)
« on: October 18, 2017, 08:30:59 AM BST GMT »
Ultra fine grinding mill is widely used by users, and it is very simple for users to care about it. Ultrafine Mill can grinding for talc, ceramics, barite, calcite, feldspar, Mohs hardness of not more than 7 level, humidity below 6% in a variety of non flammable and explosive chemicals, building materials and other industries milling processing engineering, the material can be adjusted arbitrarily between 100-325, according to the user demand for the production of material size.
ultrafine mill is composed of a host machine, a fan, a cyclone separator, a product analyzer, cyclone separator and an air pipe, the user can cooperate with bucket elevator and vibration feeder for grinding and processing in ultrafine mill.
Working Principle of Ultrafine Mill
In the material into the internal material of ultrafine mill, vertical axis rotation in the interior, and under the action of centrifugal force, rotating pressing ring roller, and the material in the blade under the action of entering between the grinding roller and the grinding ring, and then the material milling processing, the ultrafine mill principle.
Advantages of Ultrafine Mill
1. The ultrafine mill mill adopts special transmission device, and the ultra fine mill runs smoothly and operates reliably.
2. ultra fine grinding structure design compact, small footprint, convenient user operation and maintenance, can save production costs.
3. the wear parts of ultra fine grinding are made of special materials, and the product can be used for a long time, which can reduce the maintenance cost.
4. the use of advanced electrical system control, equipment can realize unmanned operation, can save labor costs, save maintenance costs.
5. high screening rate of equipment, can be as high as 99%, equipment failure rate is low, save production time.
Ultra Fine Mill: http://www.hotquarrycrusher.com/products/grinding/xzm-ultrafine-mill.html
