Author Topic: Ultrafine Grinding Production Line Configuration  (Read 139 times)
« on: October 17, 2017, 09:55:56 AM BST GMT »
Ultrafine mill is a very classic milling equipment. It has been developed for many years. Now, in many industries, we can often see its shadow. Compared with the demand of the overall development of the mill, the market demand of ultrafine grinding mill is increasing, and its application is more extensive. Ultrafine Mill is widely used in metallurgy, building materials, chemical industry and mines. In general, a group of ultra fine grinding structure mainly comprises a host machine, analysis, pipeline equipment, air blower, finished cyclone separator, jaw crusher, bucket elevator, electromagnetic vibration feeder and motor etc..
Crusher to use ultrafine grinding production line is a high-efficiency and energy-saving crushing equipment, in the design and production of inside and outside, large crusher crushing equipment has been one of the concern. It is in the ultrafine grinding production line is mainly used for crushing various ores and aggregates, first crushed to the appropriate size, sent to the host of ultrafine grinding. Ultrafine Mill  is widely used in mines, smelting, building materials, roads, railways, water conservancy and chemical industry, such as compressive strength is not greater than 320Mpa of materials. Crusher is divided into coarse crushing and fine crushing equipment, this need according to the production situation, crusher type and model materials of different configurations are different.
The bucket elevator has the advantages of large capacity, high lifting height, stable and reliable operation, long service life and so on. Electromagnetic vibration feeder adopts new vibration motor as exciting source, which has the advantages of simple structure, compact structure, convenient maintenance, continuous and uniform feeding, small material groove wear and long service life, etc.. Vibration feeder is often related to belt conveyor, rotary vibrating screen, bucket elevator and crusher and so on. It is used in automatic scale, quantitative packaging, and automatic control process. It is an ideal feeding equipment in metallurgy, mining, coal, electric power, building materials, chemical industry and machinery industry.
Of course, the above is the common ultrafine grinding production line configuration. You can also use impact crushers or cone crushers. And you can also set up a stage or two stage crushing line. In short, according to your production requirements, you can choose the right equipment configuration.
