Author Topic: Mica stone mill  (Read 161 times)
Mica stone mill
« on: October 09, 2017, 12:39:16 PM BST GMT »
Mica powder is a non-metallic mineral, containing a variety of ingredients, which are mainly SiO2, the content is generally about 49%, Al2O3 content of about 30%. Mica powder has good flexibility, toughness. Insulation, high temperature, Naisuan Jian, corrosion resistance, strong adhesion and other characteristics, is an excellent additive. It is widely used in electrical, welding, rubber, plastic, paper, paint, paint, paint, ceramics, cosmetics, new building materials and other industries, the use of extremely wide range. With the continuous development of science and technology, people open up new applications.
Rich mica production and processing equipment must be through the slag grinding process after processing applications in the industry will be more convenient, Zenith Co., Ltd. specializing in the production of ore mill equipment, energy efficient and environmentally friendly cleaning is the most significant mica stone mill Features fineness of 500 mesh, 300 mesh and other fineness is more common, stone mill manufacturer Zenith according to the use of the mill users and recommendations, in the high-pressure medium speed stone mill on the basis of updating and improving the design of high-pressure powder grinding Machine, in the processing of mica advantage is obvious, more than double the output of other equipment, energy saving and environmental protection.
Construction Waste Crusher  with high efficiency and energy saving, high efficiency grinding, low energy consumption, and compared to the ball mill, low energy consumption of 40% -50%; stand-alone production capacity, can use low electricity. High degree of automation: PLC automatic control system, and can achieve remote control, easy operation, easy maintenance, reduce labor costs. Feed size in the 50mm or so, the output up to 9-70t / h.
