Author Topic: real wood floor maintains should notice?  (Read 206 times)
Offline qizhen0809
« on: September 05, 2017, 04:59:49 AM BST GMT »
Real wood floor the floor compared with other, it can not say for sure is raised really few. Because its natural sex was caused, maintain the character of the respect. So in at ordinary times of floor of wood of the fact in use process maintain what item should notice?
24 hours of reoccupy after installation
After laid of real wood floor ends, want to raise 24 hours at least rear can use, use floor board of influence real wood the effect otherwise. And unfavorable brush with wet cloth or water, lest lose luster. If do not live for long time, must want to maintain indoor airiness, avoid floor to shift to an earlier date weather-shack with ageing. Cannot go up with plastic paper or newspaper lid, lest time is long exterior paint film is tacky, lose luster.
Prevent sun too long illuminate
Real wood floor had better not accept sunshine illuminate directly, expose for long fall in intense sunlight, or the temperature inside the room rises what demote causes cover of lacquer of real wood floor possibly quickly to shift to an earlier date weather-shack with ageing, answer to avoid as far as possible. When sunshine is point-blank, but the curtain on keep out, perhaps do to the window prevent bask in vitreous film.
Let be far from floor damply
Room humidity shoulds not be too big, can make the floor becomes because of moisture otherwise case become warped, affect the exterior already, shorten again service life. Do not bus floor with wet dishcloth. Be in rainy damp perhaps season, accomplish room as far as possible ventilated, do not pile the article with overmuch buy on the floor. What retail floor board at ordinary times is dry, bright and clean, daily cleanness is used twist dry cotton mop to wipe can. If encounter stubborn besmirch, should use the reoccupy after neuter and clean dissolvent is wiped to twist dry cotton mop to wipe, do not use the organic dissolvent such as acerbity, alkalescent solution or benzine to swab.
Wood Plastic Material Advantage
How To Install Wood Plastic Composite Decking- Seven Trust
Environmental Protection Wood Plastic Composite Sydney
Ecological Wood Plastic Composite Decking Cost UK
